Powered Bya Skyline wrote:new to the rb world, nor new to drifting or boost lol.. i stumpled across project sky40. i read every post on here. i have a couple of questions seeing that this is one baller setup. hats off to you man. where would a guy like me find a r32 crossmember? how much do they usually run? iam also curious to this hockey puck mounting system.. i saw it and knew i wanted one. i currently have a s13 iam rbing soon. its my drift slut and right now iam working on saving money to purchase an rb20det. i was planning on doing the mckinney mounts but if i can find a r32 crossmember for the same price i would rather do that. ive been researching on this motor swap for about 2 months now. i was debating on either the sr or rb. when i saw an rb swap for the first time i was sold on one. srs are way to common. not wanting to nor trying to steal this thread by no means. any input would be extremly helpfull. thank you chris
No worries bro. Yeah the xmember isnt too costly. Search around, you should be able to locate one for under $200 pretty easily. The hockey pucks havent given me a single problem yet. They feel better than the ka mounts did. I agree, I dont prefer SR's. The RB can handle 300hp without troubles with the iron block. 400 is another story (ill explain below). My setup is far from baller, just a way to get 350-400hp without spending too much on it. If youre new to the RB's try out the rb20 first, then maybe step up later. I dont understand why folks purchase the 25 or 26 and stop at 300-400 hp. Just doesnt seem worth it to me. If I did a 25 or 26 id go for 450 or more hp's. I mean heck after 7k whos countin?
touge whore wrote:hey yotik are there any updates to your turbo swap? i was really looking forward to the end result.
Yers there are updates, but not all of them are peachy. Ran into the inevitable troubles of the smaller 2.0 motor. So heres what happened:
I had a rough tune on the motor after I got CarlH's ecu thing figured out and hooked up the lc1. Did a couple test runs and everything was great. About the 4th or 5th test run I started losing coolant-and fast! A few inspections revealed faulting hoses throughout. All replaced. All is well right? WRONG. On the very next test run the HG said bye bye. Luckily, tore the head off, and no damage has been found. Going with a fully supported setup now, including ARP studs. So far ive only done the water pump, but I have a full gasket kit ready to go. Just need to get the idler, tensioner, performance timing belt and it all goes back together. Oh, and im rebuilding the turbo for peace of mind. The car pulled insanely hard after 4k rpms. Can't wait to get it all back together.
September filling up on 93:
BadaBOOM:
Teardown:
Clean and level deck:
New water pump:
