Ya I was aware of something like that. I figured since the car was on jack stands it would be as though in an assembly line. Plus I made sure not to remove the subframe during the process. I'm not saying doing this method will work all the time i'm just saying thats what i went about it and thankfully did not have any issues. Everything lined up pretty wellSkyline_BNR34 wrote:The only thing I notice that you did wrong with this build during the firewall swap was you did nothing to support the car. You cut out the firewall you should have put support braces in the engine bay and interior to keep everything perfectly square.
I'm sure you didn't screw anything up while doing the swap, but you could have seriously screwed up the straightness of the body. Especially since you took out a huge structurally supportive item in the car.
Looks good though, can't wait to see it fully finished.
