Project Sentorian - B16
djtorello
Car: 2008 nissan Sentra SE-r
If you guys need any help with your 2.5L B16, just ask.
This is a repost from MSV. Im sure some of you read it there, but those of you how may need help or direction, you can do alot to our engines. Though i do have alot of issues, this is the way i started it.
Da da DAAAA!
Ok, im tired of the hundreds of requests. If you wanna **** up your car, follow me.
2008 Nissan Sentra SE-R Bdesignation.
Videos will be uploaded later this week.
Mods list.
- Crank scraper
- Clevite 77 bearings
- Blueprinted, knife-edged, balanced crank. (cough 2oz + on 3rd counterweight cough) fixed.
- Eagle Rods
- Eagle pistons (a/f 10.1:1)
- HDE Sleeves
- HDE head gasket
- shaved and milled deck.
- 1mm over sized valves
- Port and polish head
- 5 angle valve job with back cut
- Unshrouded the valves on head
- Mild cams
- Crane springs
- Crane sodium filled valves
- Crane retainers
- ARP studs
- Bi directional sweep cut around spark plug
- NGK Multispark spark plug
- Osaka Coil packs, 45,000volt, 4 amp less requirement then stock.
- Gasket matched Intake manifold (stock)
- HDE Aluminum Intake manifold Prototype (dyno)
- HDE tb spacer
- Ford 70mm Fly by wire TB.
- PCV catch can
- Injen intake (borrowed, thanks constipated penguin)
- HDE aluminum airbox (dyno)
- HDE header (dyno)
- Rewound 150amp alt
- Walbro Fuel pump
- HDE injector upgrade
- HDE ground kit
- UR lightened crank
- HDE modified fuel rail
- Armada battery
- Test pipe
- Assorted other projects, I Love HDE!!!
Comming soon: Royalty Rotors, Custom hood in the works, Assorted suspension goodies.
I think thats most of it...
Many parts are custom or 1 off designs. HDE is helping out. There are serious problems with oil pressure and fuel pressure. As well as alot of other annoying problems. Such as cooling, and RF interferance (i love radio). Peaked 212 whp twice, usually been lower then that, but not by much. 200ish is my average. As such since most parts are prototypes, they dont stay on my car, I wish. But you guys will eventually see the fun stuff you too can play with, AFTER ALL THE BUGS ARE WORKED OUT! not before.
Modified by djtorello at 10:47 PM 9/19/2008
nametakennow
Car: '06 MINI Cooper S
Copy and paste the original post from MSV and ditch the link to comply with policy.
You're mildly insane, but doing very cool stuff.
djtorello
nametakennow wrote:Copy and paste the original post from MSV and ditch the link to comply with policy.
My apologies, So now it be fixed. The thread i mean.
nametakennow
Awesome, thanks.
Again, very cool build.
