project S13.4
Raos
Whats up guys. im new to this forum but not new to 240s or sr20s. Im starting another project car and i have a list of motor part and wanted to see if you guys could think of any other parts i could get to hit my goal of 600HP on a s14 blacktop. All input or ideas are welcome.
-Nissan 240SX S13 Hatchback-S14 Blacktop VVT
Engine/Performance- SR20DET S14 Blacktop $- Garrett GT3076R $1,189.00- HKS FMIC $ 924.00 - Tanabe Canister $ 229.50- Greddy boost Profec B II controller $ 319.00- HKS Turbo Timer $- Brian Crower 2.35L Stroker Kit $ 3,100- Steel Driveshaft $329.00- Nismo Short Shifter $ 219.00- 300zx MAF Sensor kit $ 315.00- HKS SSQV $- Torque Dampener $69.95- HKS Circle Earth Grounding Kit $ 135.00- HKS Step 2 Cams $ 477.00- HKS Cam Gears $ 335.00- Koyo Radiator $335.00- HKS Valve Springs $238.50- Splitfire Coil Pack Kit $ 420.00- Peak Boost Exhaust Manifold $829.00- Walbro Fuel Pump $ 115.00- Greddy Oil Pan $ 285.00- Blitz Denso 700cc Injectors $ 420.00- HKS Fuel Rail $387.00- Nismo Fuel Regulator $125.00- Tomei Rocker arm Stoppers $ 99.95- Taka Turbo Lines $185.00- Brian Crower Titanium Retainers $ 169.95- Nismo 3pc. Motor Mounts $- HKS Shifter Springs $ 97.75 - Nismo Colder Thermostat $ 69.00 - Blitz Oil Cooler $ 725.00- Nismo steel braided clutch line $ 89.00- Nismo Clutch Fork Pivot $ 45.00- Turbo Timer Harness $19.00 - Circuit Sport Coolant Reserve Tank $ 95.00
adrianfromthecastle
Car: 1992 Nissan 240sx
welcome to nico...
a couple of things that could help you out a bit:if your paying more than 120 on a timer w/ harness(harness is like $15), your not looking hard enough. you can get walbro 255's for like $85 shipped. hks ssqv's are getting cheaper by the months, like ive seen some sponsors selling them fro like $170 iirc brand new w/o piping (hot pipes for hks ssqv are like $60). get a z32 fuel filter, and exedy clutch. i'm sure a lot of other people can agree that those prices listed are a bit expensive (sucker prices).
ZL-Auto
Car: Zerolift Autolab - 513-874-2508 - [email protected]
Try Peak Performance orDynamic Autosport - talk to Eddie Should be able to get far better pricesthan those you posted.
Jadesr20det
Car: 1990 NISSAN 240SX
I do agree with the above those prices are a lil bit higher than what I've seen check with sponsors and google u will find better prices. Also you are def gonna need to purchase a good headgasket (cometic, greddy metal) to reach those #s
