Shane,qsiguy wrote:I'm not sure what you get with the Conzult. Mine has a Consult plug on one end, goes to a small circuit board, then has a USB cable that goes to the laptop. This is just for the logging, map trace, etc. You don't need this cable to burn chips but you need it to monitor the car/ECU. You'll also need a consult adapter and the Ostrich to use Nistune.
After swapping chips in the ECU about a dozen times you'll be ready for the real time tuning
The conzult came with pretty much the smae thing. Consult connector on one end - circuitry - USB. I think it should work. I'm planning on the Ostrich setup so I'll change the chip once Other than that I'll probably use what you're using/recommended.
I think it'll be verrry coool!
Thanks Shane,Nick.
