I hope to not have a hole in hood. I used a front sump, so I may be a lil lower, on overall height. Either way, I had hood on and was within an inch all around, so Plan to take out hood support and then bulge it as needbe.T45 wrote:Oh yeah, prepare to get a lot of stares! A Z with an engine sticking out of the hood combined with the exhaust note of the VH makes for a truly wicked ride!
DON'T DO IT. 270 ft-lbs...torque it. Did you notice that the sprocket on the crank for the oil pump is sandwiched between the two timing chain sprockets that are keyed? It's meant to slip when the oil is cold and the engine gets revved. Over torquing is just as bad as under torquing in this case.craigztoyz wrote:hope the oil issue gets worked out. I am planning on using an impact to make sure crankpulley is tight as hell.
Remove the starter, lock the ring gear with a big screwdriver and torque away Or convert to manual, stick it in 5th with the hand brake oncraigztoyz wrote:How do you recommend tightening crank?
I am so glad they'll clear. Luckily with the garage being detached, I don't think the wife and kids even hear the compressor kicking on. Pretty fortunate I guess. I think I will be doing the turbos in the nose where the airbox used to be and then run to the factory ICs. This will allow me to recycle the rest of the plubling openings to get to the throttle body. I was actually surprised at how thick the wall of the tubing is. Pretty stout.craigztoyz wrote:Nick, as we spoke on phone and I measured, yeah, I think that will clear quite well. I like the pics of how you cut it. Wife n girl must love the Sawzall n its delicate sounds. I had tried to flip them over before but due to ubstruction, dropped it. Glad to see you have made it work. Best spot is going to be in front of radiator, with i/c on outside, or viceversa, turbos out though may be too much heat in the space in front of tires, and melt the bumper n such.
The beauty about redoing the header is I'm going to add flanges in the appropriate locations to have removable downpipes with wastegates and another set that's straight through. If done right I should be able to set the car up to run normally aspirated to start with and then add the rest of the plumbing for the turbos and swap the downpipes with the wastegates on them. I also researched it a bit more and 38mm wastegates should do the job 60mm would be overkill.craigztoyz wrote:So much for stage 1. or plan a, I mean.
That's awesome. I will probably take the hood to a customizer and have a bugle added to it and then have the hood repainted. Similar to the so called "power bulge" on the M3 - it'll look stockish this way like the bulge was always there. It's fantastic that you got the motor sitting as low as you did. Great job! I can't wait to get mine in there.craigztoyz wrote:I can't wait to weld in that a/c garage. I got a lot of pics to come, and oh yeah.
check out this pic. this is with the motor in the car, intake on, and everything except piping from the tb. the hood comes within an inch all around, take out 1/2 of hood support, and bulge it a bit. Next one, I am dropping the rack an inch or so, and using different endlinks to make it up. But this is almost under the hood, A heck of a lot more then I thought it would.
Nick7 Days and counting. Next Mondany, end of 3 day weekend, thats the plan. gimme a ring when back, let me know whats up with swinging by. Craignpez wrote: I can't wait to get mine in there.
Thanks,Nick.
Thanks for the feedback. I've got the manifold off and hopefully I'll be able to drill out the spot welds and cut it like the other one to drop off tomorrow.....tmorgan4 wrote:That sounds like a very good price to me considering the amount of work involved and the fact that he's going to TIG it all. A friend of mine at a race shop I met during this project charges $150 an hour for all his TIG work, and more if he's fabricating too. As long as the guy seems to know what he's doing I'd jump on that.
Shane,qsiguy wrote:If you can do front mounts that's probably what I'd do. Although it could end up being as much work, or more, as the rears tho with all of the modifying you must do. I'd like to see a complete photo of the bottom of your 300z. Curious what plumbing routes are available.
Yeah I put all the parts up in the attic.craigztoyz wrote:Wow that is a clean garage!
I dropped off the manifolds this morning. We'll see the progress after I get back from vacation. I'm waiting on a quote for the turbos, flanges, oil lines, etc. and once I receive those and purchase, then I will finalize the layout in the engine bay and have him permanently weld.craigztoyz wrote:Those prices sound great. If you had access, you should take him the motor, so he could build around it. Sounds great.
It'll be great! I'm sure of it.craigztoyz wrote:I still think that rear turbo is very doable. Hope to one day, but for now, see what she has with this.
