npez wrote:Hello Everyone,
Just a quick update. Craigztoyz came over this afternoon and after a lot of work we got the crossmember modified and the engine back in and mounted. Everything lined up perfectly and we did the cruise control bracket mod as well. After this process it appears that the factory power steering pump will not fit (sway bar clearance issue). Thinking about electric p/s from MR2 or similar - if anyone has any other recommendations for this I'd love to hear them.
I've got to do some cleanup work and re-spray the cross-member, and then I'll take pictures and post. Sometime next week I should be receiving the 555cc injectors, orings, and hicas eliminator and will install the hicas eliminator the rest will wait for another couple of weeks or so.
The turbos are going to end up in the nose of the car as it is impossible to get plumbing to run the air filters from the turbos in a sidemount orientation (the turbos have 4" inlets so there is no cast small radius elbow to accomodate the restriction). So with that said, I will design a bracket to hang them and then will tow the car sometime next week to have the manifolds and exhaust system done. Once complete (this will actually take 1-2 weeks for the full exhaust with tie ins to the factory exhaust) I will have a 2.5 inch turbo bypass pipe with a turbo inlet flange on one side and a 5-bolt flange on the other fabricated, so I can remove the turbos and run the car initially in normally aspirated form.
During this time, I will try to order the rest of the parts I need in order to get the car running (fan controller, water pump pulley, hoses, belts, etc.) as well as some phase 2A parts (scavenging pump, nistune, ostrich2) with the phase 2a parts needing to wait until after father's day.
That's the plan at least. I'll keep you updated with the progress being made and will post pictures when I take some more.
Thanks again to Craig for all the hard work, a very long night, and a job well done!
Thanks,Nick.
Nick, It was fun, tiring, but fun. got home about 6:30 am, flying about 95. I was up 26 hours in the end, but all worthwhile.
I am very happy with the mounts, and sure that even with what you are throwing at it, (Guys, to see the compressors on these turbo's in hand, DAMN) I am sure that the mounts are not going to be a problem. Wish I had brought a small grinder (1 1/2") to get it really cleaned up in the small areas. But oh well, I can see how much pride you take in that beautiful car, and am sure you will enjoy the time spent.
On the car- WOW. the hood has never been off the car- factory seal on mounts. very clean, and sweet exhaust tips. rims n tires, are a really nice choice.
Garage- Very uncomfortable, horrible working, conditions, Yeah right. Funny I am in there grinding away at 2 am, windows open, a/c on, relaxing, standing looking at the mounts at eye height. Agh to be so lucky... and most of all, on having a wife, who is ok with all this, and buys you that lift, and that was before you blew the motor. Lucky, and the girls of course, adorable. Thanx again, and well, sorry my son is a handful.
This is going to be a very wicked car. I can't wait to take it for a spin.
Thanx again, for the fun, and I will be in touch later in weekend. Craig
