Mailnly for building a carbon base quickly. The roughness helps build the carbon layer faster. Basicly if I left it as is from Wiseco then it would take longer to build a good carbon base. I don't know much about coating the tops of the pistons I would guess it would help with temps. TOO would know more than I do about that.
Here is a quote from top engine builder TOO, aka The Old One."Most techniques used by head porters for re-shaping combustion chambers rely on the use of abrasives like cartridge rolls, which can be used to blend numerous complex shapes together smoothly. Typiclly, this will leave a semi-polished appearance. Some shops will use finer-and-finer grits of abrasive to create a highly polished combustion chamber, which is great for "looks", but lots of testing over many, many years continues to show that an engine has to have a base carbon layer on both the chambers and piston tops before it will make it's best power.Highly polished chambers require more time for this base carbon layer to develop."
Cutting down the sharp edges also has a positive effect with the flame front in the combustion process. What exactly I have not a cluse but I take his word for it.
I don't believe I'm getting a hook up on the machine work. He is very reasonable with his prices and does an excellent job. Heres a link to their website.
http://bbandtracing.com/
