REZN wrote:my manual says to use premium but when i did use premium.. i didnt catch a difference.does it last longer? does it help the engine life?
Actually, that depends. If you're light on the foot and don't run the RPMs up that much, doesn't make any difference.
If you like to pop up to redline a couple times a week, I'd recommend premium as it'll knock less (you'll never notice the knock as it gets retarded before you can notice, but it happens slightly).
I notice the performance difference on my M35 when I run premium. Infiniti recommends it, but not required. When I'm romping hard I get no hesitation in higher RPMs. But if I'm running regular, it has trouble getting up in the higher RPM ranges.
