After all the drama was said and done I started to enjoy my car quite a lot. The car held up until about three weeks after I got out of the Marines and the engine decided to get a rod knock. I decided that if I was going to do it I might as well do it big. I found a decent deal on a U13 bluebird for $1000 with ecu and wiring harness. I did the swap last August and have not stopped doing add ons since.
Here is a list of most of the work I have done:
1993.5 Nissan Primera (P10)
Tires: 215/40/17 Sonar SX-1
Wheels: Sentra Spec V 17” Rims
Engine:
SR20DET U13
U13 ECU
Godspeed T28 Turbo
Brian Crower Stage 2 cams
3" aluminum intake
Spectre Intake filter with MAF adapter
Custom powder coated valve cover
Powder coated manifold and turbo covers
Nismo type B Fuel Pressure Regulator with adapter
Carbon fiber 100 psi inline fuel pressure gauge
Walbro 255 LPH fuel pump
Godspeed Front Mounted intercooler with 2.5“ piping
Godspeed Sentra racing radiator
Carbing radiator cooling panel
Reinforced engine crossmember
Custom Made 2.5“ Turbo back exhaust
Magnaflow high flow cat
12” resonator
BKR7e-11 Plugs
NGK spark plug wires
Z32 fuel filter
Battery relocated to the trunk
Transmission:
B15 LSD
Eclutchmaster stage 2 clutch
Ralco RZ short throw shifter
Stiffer bushings
Interior:
Upgraded vinyl power seats
Wizim Popformance Electronic Boost Controller
Pioneer deck
Pioneer components
Overhead and map bulbs converted to LEDs
Instrument Panel bulbs converted to LEDs
LED friendly flasher
Dash mounted Oil pressure and Boost gauges
Center console customized for Electronic boost controller and CD player relocation
Custom cup holder
Exterior:
Car lightened to 2480 lbs
VVME 8000k 9004 HID Kit
Euro Tails
All bulbs converted to LEDs
Custom made grill to protect intercooler
Auto sculpted front bumper for intercooler and piping fit
Antenna X Antenna
Nissan hamburgers and Primera badging
Rear fenders rolled
Suspension:
KYB AGX’s adjustable shocks and struts with bellows
Tein S TECH lowering springs
Stillen front strut tower bar
Carbing rear strut tower bar
Polyurethane Sway bar bushings
Front suspension mod (thanks Jer)
Future mods:
2.0eGT badge
HKS Type 1 Turbo timer
Nistune
Powdercoat: Rims, FSTB, and a few other odds and ends.
AADCO rear antisway bar
Harness Bar & Nismo 4 point harnesses
What my car looked like when I started
The old SR20DE
The old SR20DE being pulled
The start of the swap. You can see the marks on where we decided to cut the bumper and place in the front mount
The SR20DET getting a new home
You can seen where we cut and reinforced the bumper for the front mount. On the ground is all of the exhaust parts that I used.
Close up of the engine just put in the bay
We did some fabricating for the intercooler piping to run
We had to trim this guy down a little as well
What the engine bay looked like after it was all said and done
A low shot. You can see my ghetto mesh grille that I made out of mesh that is meant for tiling a floor.
A front shot of the project
Boost and oil pressure gauges
This is how I ran the wiring and the boost line for the gauges
Then I did some body work and got the car a new coat of paint.
New antenna. The OEM one was broke loud and annoying
I had some racing seats that were intended for something else but I threw them in because they matched the interior perfectly.
Then I did a dyno run for some base numbers
7 PSI
WIZIM Popformance EBC
UN Third Brake light cover
The OEM wheels looked like garbage so I got some Spec V wheels for a killer deal from someone who know a fair amount about P chassis
I threw on a temp valve cover while I was getting mine powder coated
Then I got mine powder coated from some Unknown coater
My cluttered engine bay
8000k HIDs
I will update this thread from time to time when things change. Lastly I have to say thanks to Little John for all of his help. Without his help the car would have never turned out the way it did.
