that setup or similar, has given many member on here a blown enginesommmatt wrote:N/A KA huh. For a DOHC...
Port and Polished Head with 3 angle valve job.Oversize valves.Titanium Valve SpringsCrower CamsITBs. 4-1 Header. Forged SOHC Pistons Lightweight Forged RodsReal CAI2.25 inch straight pipe exhaustLightweight flywheel1 piece driveshaftGood tune
A setup like this will give you huge compression, a head that might flow decently enough to give you power up top, a good breathing exhaust, a good breathing intake, and fast revving with minimal vibration. The forged internals are to keep weight down.
and after all of that is said and done..........ztunelover wrote:the z32 uprights are 16 pounds lighter the coils if i go jic would be roughly 5 pounds each front 3 pounds each back. the entire nismo suspension link is about 10-12 lbs lighter. the rims would be lighter for sure, the driveshaft is cf so im positive that thing would be a featherweight. how much does the stock 2 piece weigh anyways? 20lbs? cuz i know the cf units are 8 or 9lbs. unsprung weight really helps around turns.
All s14/s15 sr20de's have variable valve timing on the intake cam. If the wiring is done right you can keep the VVT, aircon, etc...ztunelover wrote:does the sr20de s14 model have the vvt thingie? and how much are they to install. sure they would make some crazy power n/a cuz thats what tomei sr20s ran in the n2 series. i dunno lets see. i do plan to eventually built it. i might just buy a s13 hatch rolling chassis.
I think I would rather be 8k closer to having a Running RB......... it would take a ton of f***ing up to screw up 8k worth of errors.ztunelover wrote:the reason i believe is clear. the motor even fully built would cost me less than 8 grand. the rb26dett would cost me over 60grand possibly over 70 grand to build. and then theres the r32 chassis, aero prep and everything. i highly doubt a 60k motor is the est motor to practice on. a ka is pretty damn cheap, easily available has some aftermarket support. and im doing the ITB's because i want to practice before i start tuning the rb unit.
just out of curiosity would you rather practice on the 60 grand motor or the 1 grand motor. and i mean 1 grand by a vast overestimate(ka motors are much cheaper here), whereas the 60 just might be less than the actual cost.
and the uprights alone would knock 0.1 off the 60ft time. thats the difference between unsprung weight, and normal. thats why a lighter powertrains suspension system would do more than removing the back seat etc. and the lightened body materials focus on the upper part of the car = lower cog. if one thing matters less to me than anything its the quarter mile time. a lap time on the other hand is very important. and trust me lighter stuff there helps.
There are a few engine importers that operate around Newark NJ because its a huge port for the east coast. I got mine from JDM Engine Zone, 90-day warranty and I got to inspect everything first. I found another too at a place not far from that shop. Both places said its not a regular stock item. If you're paying more than $1000 for a s14 sr20de, you're paying too much.hbpignosePA wrote:
i know jhot gets em from time to time. with VVT can you still change out cams that are designed for the turbo versions?
i was thinking of doing a built head and raise compression using an approprate headgasket thinkness (i think thinner raises it)
I didnt say anything about spending just 8k on an rbztunelover wrote:8k is my upper limit, i intend not to hit it. 1k ITB, 1K built motor, 400-500bucks valvetrain. 1.5 grand for exhaust system and my ghetto cai that was originally a aem short ram, supporting fuel mods 500 bucks. nistune another 500 its still have 6k only. funny you should mention a 8k running rb
http://www.403drift.com/produc...D=653
9.5k for the rb.
and no i have higher plans for the 32 than the average gtr so just an average running gtr wont do for long. i have to make sure my rb can run 4 digit numbers without sending pistons flying everywhere.
and i can understand if you do. but this 240 is my first car. and by the time the r32 sees daylight again im positive that i would have enough experience to trust myself to build any car.
