glitched »
https://forums.nicoclub.com/glitched-u17528.html
Fri Feb 20, 2009 5:41 am
The KA isnt a motor worth worrying about dampening.If you just get a lightweight crank pulley and years down the line something does go- then you have an excuse to rebuild the motor for more power or swap something else in. Or even just pickup another cheap KA.
and I still believe in getting as much power to the ground because we are talking about small numbers with a NA KA.
Track down some rare underdrive accessory pulley's, crank pulley, switching to electrical fans gets rid of hte mechanical fan weight as well. Lightweight fly wheel, aluminum drive shaft( I love mine), and some light weight wheels. after driving with these mods, driving another 240 even with I/H/E would feel lethargic.
while your at it, start going with overall weight reductions as well.
Before every season i do a full tune up as well, Red line synthetic oil everywhere, motor, trans, and diff. new cap/rotor/plugs/wires, new z32 fuel filter. Clean the MAF sensor, properly re-oil the K&N (with another cleaning of the maf midway through the season incase any K&N oil gets on it) new TPS even.
If you want to actually compete at an autocross, you need to worry about tires and experience first.
