95-J30tt »
https://forums.nicoclub.com/95-j30tt-u40286.html
Mon Jan 08, 2007 6:07 pm
nice job, i had delt with something similar, i dont know much about the stock engine of the M30, but i'm assuming it is almost the same as the J30 with about the same space in the engine bay (code VG30DE, i believe that the M30 has a code VG30E single overhead cam), any how, it took me forever to firgure out that the engine mounting brackets of the J engine would fit the TT motor, believe it or not, it does fit, it has a different bolt pattern...., but the pattern for the J mounts were there also and they were threaded too, so that made things a lot easier, try (although it sounds unreal) to take out the mounts that you had on your stock engine, and find a place for them in the TT engine (if the M30 engine has the same block as the TT, then the bolt pattern is there, you just have to find it, and most likely it will also be threaded and there waiting for you), and you can use your stock rubber mounts or the TT mounts, there is one bolt (i think it is on the driver side) that will be impossible to put in without taking the turbo actuator out of the way
As for the turbo hitting the stearing rack, do you mean that it is hitting the stearing column?, if it is hitting the column, then i had the same issue, if you are taking your time and have a helper drop the engine in with you, then you shouldnt have a problem with it getting past that column, but check first if it is going to constantly be in contact with the turbo, if it is, then grind a little off the turbo exhaust (in my case it was the exhaust), do not mess with the column, you life can depend on it.....
did you get down pipes with the TT motor?, when you buy a JDM, they usually give you part of the exhaust with the engine, dont discard it, it will come handy later
for the oil pan's turbo return lines, i had the exact same issue, i drilled holes in my pan and welded short metal pipes, that way you dont have to worry about them not holding up to the pressure, take measurements first, and watch out for the location of the holes that you are going to drill (i learned it the hard way....), there is a black trauss on each side that supports the transmission to the TT engine from the bottom, make sure that the pipes that you are going to weld wont interfere with those trausses
when you drop the engine in next time for a test fit, pay close attention to the location of the oil filter bracket, if it sits close to the rack, then just take a picture of it, and i'll try to help you as much as i can, i have the transadapt catalogue (they make oil filter relocation kits), they have various kits, the one that worked for my setup is part number 1413 (that is only for the part that connects to the stock bracket, and not the full kit) last but not least, for the first 4 times or so you test drop the engine, dont expect the engine to just sit perfectly, expect something to pop up, that way you wont get frustrated every time you take the engine out to work on it, i hope this helps, keep us all updated, and i just want to say that what you are doing is great, i'm almost done with the swap on my J and i know how hard it is without a write up
sorry for the lengthy post
