So i finally gota chance to swap over my exhaust from the vert,also thankzz to my buddy's dremel i was able cut the headers w/ cat off with damaging cheapo exhaust
done!!(Im ripping that wing off soon)
Ok guys i cleaned up my dirty a$$ engine bay and mounted my J30 brake upgrades:gladtomeetya:.
Driver side strut tower base NO RUST but dirty as hell and paint chippingand the same goes for the other sidefire wall(The heater inlet and outlet look like to 2 nipels dripping milk):mysmilie_793:
Let the scrubbing begin!!!! After about 60mins of scrubbing,wire brushing more scubbing,rust treatment and paint.Also i threw in the wiring harness since im pretty much done with engine bay.What i use to treat any surface rust i had and paint for the bayLOOKS LIKE NEW!!
Moving on to the brakes at last,my rotors fresh from the shop from being cut and drilled:rotflmao:.comparing stocks to upgradeed
Soo i tried to cut this dam shield and i failed badly:zbanghead:I when thru like 3 blades and only have cut 6inches
Soo i came up with the idea of cuttung tabs or w.e. you call it then straightening out the metal in order for th rotor to clear.And bam!!! its clears all(my passenager side came out looking like sh*t) but driver side look a lot better
Once everything was mounted and tight my car was loooking baller
Only problem i need to replace my driver side caliper i think the weather got best of and it froze up on me.I might replace both tho
My ES rear subframe inserts have been ordered and should be here by friday,there will be more pics.Thinking about what to order next??any ideas??
tein tie rods?brake line all around?engine gasket kit,headers,asp crank pulley,new clutch and poly fill stock mounts...etc(soo i can start gettin the motor ready for install)?Or be a cool kid and do hoodrat stuff with my friends?
