andrave »
https://forums.nicoclub.com/andrave-u6358.html
Thu Aug 26, 2004 12:16 pm
some people have been asking me about how my twin turbo project has been going.well, we swapped and everything, and bolted an exhaust manifold up and ran the mafs by the TB and I could not get it to start. I had to leave for texas the next day. I did not get to try anything and I'm not sure the wiring is all good. I had a couple light green wires left over on the body harness connector, and a plug on the sohc transmission harness didn't plug in. there was also a ground wire on the pass. side of the dohc block that didn't have anywhere to go, its under the intake manifold. Its worth noting I used a 92 ka24DE engine harness, wired it into the sohc body plug, and used the sohc transmission/subharness. I also eliminated the emissions equipment.
also, I followed JWT's wiring instructions for z32 mafs, but I am confused. one of the z32 plug wires is significantly thicker than the rest, and then on the opposite side of the plug there are two wires together in a common white sheath (one black, one white).the jwt instructions say the black in that sheath is a ground, the white is the signal, and the thick wire is +12 volts. I wired it this way, but it is possible that the thicker wire is the signal wire, and the two that share the sheath are ground/positive?
I am sure I am getting spark (checked with timing gun) and we can smell the fuel, but I'm not sure the injectors are injecting because when cranking there was no fuel coming out of the exhaust manifold. I thought that if the injectors were cycling and the engine not turning over, its likely that at least a small amount of fuel would be pushed through the cyls and out the exhaust, no?
Anyway I won't get to work on it for a while because its under a tarp in WV and I'm in TX, but with some help and a little more work maybe it will see some pavement sometime.
I also had just purchased brand new falken azenis tires... and I never even got to test their super stickiness.
