evildky »
https://forums.nicoclub.com/evildky-u13100.html
Mon Feb 09, 2009 12:47 pm
your best bet is to use the senders fomr the ka, at least the ones that can swap over, the coolant temp, most GM sensors are a lot larger than the nissan/datsuns enders, so you'll need to get a plug then drill and tap it to accept the nissna sender, , not sure of the HB has an oil pressure gauge, been too many years since I woned one, I believe the tach singal will work with a V6 hb tach
