3dKa24 »
https://forums.nicoclub.com/3dka24-u42400.html
Tue Jul 25, 2006 4:56 pm
What kind of money are you planning on putting down?I'd say Stock tune that piece Wires,plugs,oil change, transmission fluid, coolant change,new brake fluid etc.,As for mods drop a 4-2-1 header, BC V2 cams, Cam gears, SAFC 2 go to a shop get those cam gears and SAFC tuned should get you a decent chunk of power from stock IMO.As for suspension get some Urethane Motor Mounts, check all bushings and see what needs to be replaced and do so get urethane if possible, Get a larger diameter sway bar. Should get you some better handling with that Spring/Combo your getting also make sure you get alignment done after you drop it.Good luck
