MadSideways »
https://forums.nicoclub.com/madsideways-u3356.html
Fri Jan 24, 2003 9:48 am
You'll have to run 14-16psi, (ofcourse you don't have to follow this route, and I may have missed something), but you could go with:
Pre-Turbo Stuff:-----------------------1.) After-Dark Tuning Turbo Prepped KA Block (Rods / Pistons / Bearings / crank / etc)2.) Custom 3" exhaust (w/flexible downpipe, High flow Cat, and APEXi N1 can)3.) Upgraded Clutch4.) With that much HP I would go with a 3.917 or 3.700 vLSD rear-end, so that your still streetable....
Fuel MGMT:-----------------------5.) JWT ECU (tuned for turbo and z32 MAF)6.) HKS Super-AFR (makeup for where JWT ECU lacks)7.) JWT Fuel Rail8.) 440cc injectors9.) z32 Fuel Filter & MAF Sensor
Turbo:-----------------------10.) Electronic Boost Controller11.) NSport STAGE I Turbokit w/FMIC - running 14-16psi
You won't be able to get this kind'a HP out of a KA-T without proper tuning. You atleast want to learn about air-2-fuel ratios, compression ratios, and predetonation before you jump in deep end...
In any event, you're talking 'LOADS' of money....I would settle for an easy to reach 220hp for now. Which some people have attained for less than 1500$....
