project cecka (KA24DET) pics inside
frosted flakes
cecka and i worked on his ka turbo build up its bad ***...
for more information visit his site:
http://www.cardomain.com/memberpage/475154
574-240sx
Car: Nissans, Toyotas, Subaru
Dam that valve cover looks just like mine but I sanded the letters and polished them. I also didn't paint my front timing covers.
NX95240
Car: my KA-(sc61)
looks really good..
TrunkMonkey
Car: 2000 Lincoln Navigator
ooooo....purrrrrrdyyyy.
-demetrius
Drift Machine
Car: 1991 KA-T 240sx
very nice
chandler
Car: 91 civic hb & 96 S14
thats a nice looking motor, that gives me some ideas for mine........powdercoating...........paint...........what kind of mani is that by the way?
fiznat
Car: Grown up :(
ssautochrome?
looks nice!
frosted flakes
yup ss autochrome manifold...it looks pretty decent quality...not the best but i doubt that it will crack...its pretty thick material..only one way to find out huh...
BomexS13
Car: '89 Nissan 240SX
'00 Toyota Celica
where did you get the manifold?
frosted flakes
ssautochrome.com
BomexS13
'00 Toyota Celica
oh is that the $800 kit that they sell there
bbandit
Wow... thats one beautiful KA....... I've never seen one sooo pretty before.... :drool:
frosted flakes
no he just got the manifold there turbo is from turbonetics...wastegate is tial
rps13 sr
Car: cars
http://www.nissaninfiniticlub....58107
check this out!
240driver39
rps13 sr wrote:http://www.nissaninfiniticlub....58107
check this out!
wee..lets beat the dead horse to a pulp now.
koukiKA240
Car: 1991 240sx KA-T
did you get paint in the intake part of the head???~sam
Charlie240sxt
Car: 95 240sx SE Ka24det!!! 98 audi A4
Best of luck check tony Tell the boy JWT i dont think he put much thought into timeimg and fuel it will do both for him
mys13240
Car: 1990 240sx hatchback(for sale) 1989 240sx hatchback (KAT PRoject)
This is my kat buildup.
No, i didnt get paint in the head at all b/c the machine shop painted the head for me.
No, i didnt buy the ssautochrome turbo kit. The only thing from them is my mani. i didnt want to spent that much on one, and i didnt want to get the jgs b/c i dont have a welder to finish it. i also dont like the log-style manifolds. Hopefully the ssa mani will work long enough untill i get a welder to make my own custom equal-length mani.
i planned on putting the rest of the motor together this past weekend, but the damn machin shop ordered me the wrong gasket set. I took the SOHC kit back and the kits for the DOHC are $41 more. Im kinda broke at the moment so i guess ill have to wait until i get my next paycheck. I still need to get the turbo oil lines and fittings, modify the oil pan, get some belts, thermostat, distributor, and DOHC power steering lines. Im supposed to get the ps lines from this guy jeff that parts out s13's, and im hoping i can get the distributor from him also.
Ive got some questions. 1. as far as the power steering, do i just need the lines, or do i need the rack too?
2. What timing should i go with?
3. What should i use for the oil feed, and return oil lines?
4. I got a oil pressure gauge, so wouldnt i need a 4way fitting to connect it, the stock pressure switch, and the oil feed line?or do i even need the stock oil pressure switch?
mys13240
bump
bruinbear714
mys13240 wrote:This is my kat buildup.
2) Depends on how much boost you're running and what you're using for fuel/ignition management.
3) The JGS oil feed and return lines work. Make sure you get an oil restrictor. Also, make sure you get the 4ft oil feed line, and the 24" oil return kit. Anything shorter than those and there won't be any slack.
4) You don't need the stock oil pressure switch if you don't mind the oil light being on and rely solely on the oil gauge. Otherwise you would need a whole slew of adapters and 3-ways to convert from BPST TO NPT and vice versa. And the whole assembly might be so long that it'll hit the alternator. My setup almost did.
rps13 sr
Car: cars
as far as my experiance u only need the lines
i swaped over a 91 ps line to a 89 rack when i did my sr swap back then
Projex240
Car: Dogs , My RIDE
why does he need an oil restrictor--the jgs lines are only 3an--
Also--you should be able to use a T to use both the stock gauge and the autometer one. I dont know though--i lost my oil pressure sender--so I have to order a new one to get it to work.
95_240sx
Car: My baby (car)
Very nice looking motor man.....but gosh thats a small turbo
Rick
