Project Car
AZdrifterXX
I want to buy a 240 SX and make it into a drift car but also be able to drive alot. I wanted to know if i really had to do a motor swap or what the best motor was if i couldnt do a motor swap. Also what about modifying the suspension should it be stiffer or ? and also tires what kind? if u could hit me up with some info that would be good. thank you
fantabulous
Car: s14
do a search. tons of info at your fingertips.
Neejay
"drifting" is the only reason you bought the car? You dont have to swap the motor to drift. Just have RWD and manual. As mentioned before, do a search, here on nico and google.
