Just in time to sit in the garage! Yay!ILoveMyRHS13 wrote:It'll be done before winter, BRAH.
i heart gripBumnah wrote:Totally diggin' those 245s front and rear. So much grip, especially for the power level you're at.
What are the alignment specs you're going with? I'd run 2.5 negative front camber, 7.0- 7.5 front caster, 0 toe. In the rear. 1.5 negative camber, and zero toe, maybe a slight toe in, but I'm happy with 0.
Those falken's will like the negative camber.
Best update evar.mrgreeneyes wrote:even with the PVC alignment.... shes a monster......
Thats cool. We'll have a York home course and a Lancaster home course. Nighttime will def be straight cruising, unless your really comfortable with the road. Im sure MGE has a Lancaster course picked out already.Didderson wrote:
Dale, great suggestion. I'd want in, but I won't be going all out, just cruisin. 2 desires, daylight, and non competitive speed. Maybe I best stay home up to u homies.
Modified by Didderson at 8:47 PM 8/27/2009
get in linebrn-n-jpn wrote:
if only i coulcd get the electrical problems worked out hint hint
i cant hold EVERYONE's hands.....White Comet wrote:get in line
Bumnah wrote:Looks so much better with a rear bumper.
