First thing I did was update the gauge cluster lighting.
The brakes were in desperate need of attention, it looked like it had new pads but the rotors were long overdue to be replaced. So instead of an OEM replacement I decided on a Q45 brake upgrade. So hit up ebay and found some OEM refurbished calipers, new rotors with ceramic pads, hit autozone up for new caliper brackets and hardware then today swapped them out. The process was SUPER EASY, just like a regular brake job and swapping out the calipers. These brakes have so much more stopping power than before! One thing that I would like to point out to the noob car enthusiast is that you WILL need to purchase new calipers, rotors, caliper brackets and hardware (caliper bracket bolts, caliper pins, pin boots) to do this conversion. But once you roundup all your necessary components its a breeze. Total brake upgrade cost me $200 maybe.
Before:
And after:
I even replaced one of the lug studs that was broke off, because race car that's why
