I placed a piece of construction paper on the rail and then got under the tub and traced the lip then cut it out and transfered to metal and cut that with a cutoff wheel and rounded it to the line with a grinder.krayzie94 wrote:Amazing build you've got going on here, bro. Great job!
I know you're far past this, but would you mind explaining how you made this piece?
I'm referring the the flat piece that is welded on to your custom wheel well.
Specifically, how did you make the curved part? Did you make a template with paper and then traced it onto the metal?
