Progressive coilovers
TDot
Car: 2008 M35X, Lakeshore Slate/Tan
svard75 wrote:Bottom line, the reality on using coilovers is it will be a stiffer ride unless progressive springs are used. Ive always used springs with new shocks/struts and have been very happy with them. If you want a smoother feel use springs if you want that gokart feel along with the harshness go coilovers.
This is exactly what I was looking to find out. Progressive vs linear on coilovers is the cause of the harsh ride issue all my friends talk about. I thought that was something to look out for only on lowering springs. They could never explain it, they all simply said go with springs instead for a nicer ride...and they all have multiple experience with both. AFTER :facepalm: buying the tein springs I started analyzing the whole strut/spring/suspension make up and simply thought everyone was setting their car too low so they had to set the struts as stiff as possible, hence a rougher ride. If I got the coils, I would pretty much set it at the level the htech would drop to so I wouldn't have that problem. Now I see that height in conjunction with it being a linear springs makes the situation worse. I searched other places and saw others said the same thing about wanting progressive springs with the coilovers for ride reasons. I was on the fence about going to D2 for this reason until now. So now I guess I'll stay with my springs.
This leads me to create this thread. Why then is a "true" coilover so great if they come with linear springs? Why not get a coil/spring setup and swap out the springs for a different spring that is progressive? Or get the d2 and swap out the springs for progressive ones? Go to a company like this Summit where they specifically design springs for coils with customizable sizes. Wouldn't that solve all problems? Am I looking at it too simplistically? I wouldn't go this route now because I don't want to deal with the corrosion/rust issues here in NY (because I'm simply not going to add another thing to the list of things I have to maintain on this car), or the squeakyness that seems to pop up over time with coils; but I think it would be a good discussion and exercise for people really interested in coils that crave the progressive style.
Ilya
As stated in the other thread...I have BC's set to the softest setting and only 2" or so drop (1-2 fingers between car and tire). I didn't notice a huge change in comfort...it's just as bouncy/soft as it was before the coilovers. The two benefits of the coils is: 1) better handling and 2) better aesthetics.
I'd do coils all day. Yes the maintenance sucks but I honestly have been slacking on mine...lol.
svard75
Car: 06 M35x
There are some very unique coilovers that have tender springs along with the linear springs. Eibach makes custom springs http://eibach.com/america/en/performanc ... er-springs
If you can convince them to make you a set for D2 coilovers I would jump on a set too. Remember the set with the tender not helper. The helper spring is simply a very loose rate spring that allows for the full extension when used on 4x4 jacked up cars so the main spring doesn't fall out of alignment and bind.
