progress pics _ new front bumper
houdini
Car: 1993 Nissan 240SX Convertable
2001 Nissan Frontier CC
No quite finished, but taking shape. Big thanks to Richard (frontier2k1)!
Still got some things to finish up, but I will get it done quickly. Just glad to have some steel on the front end again.
The old (busted up in GA)
The New.....bigger and better!
Dano
Car: '05 Nissan Frontier Nismo CC
'95 Nissan 240SX base
That looks sick! What are the specs on the steel your using?
-Dan
houdini
i couldn't tell you what the specs are, but this bumper incorporates 1.75", 1.5" and 1.25" tube. richard (my fab guy) orders all the steel before i show up and i really just get involved in design and fabrication. i'll have to ask him.
Dano
Looks great! Planning on adding more lights I see
-Dan
houdini
DanO wrote:Looks great! Planning on adding more lights I see
-Dan
you know it!
first coat of clear is drying now. gonna do a couple or few more coats and then install all 4 hellas and put on the truck. excited about the clear. looks good thus far.
Big-Bird
Car: 2000 Xterra on 'Roids & 2004 Quest SL
I llike the pre-runner style. Boo-yah!
Dano
Yep, so do I!
Really gives me more ideas and inspiration for when I get my truck.
-Dan
Desert Rat
Car: 2014 370Z M6 Base Coupe
2017 Frontier 4.0
2007 Dodge Ram 2500 Cummins Quad Cab 4x4
1977 F150 4x4 Shorty BUILT
2008 Boulevard C90T
Previous owner of a bunch of Nissans
Looks real good. similar to mine even.
houdini
Desert Rat wrote:Looks real good. similar to mine even.
thanks! yep, it is similar. got any good pics of yours to post up? i would just like to take a look.
NewNismo
Sweet!
Desert Rat
2017 Frontier 4.0
2008 Boulevard C90T
Here's one
houdini
nice desert rat! does that tube turn back and connect into the frame or subframe for support? still trying to decide how to better brace mine.
clear is dry and lights are on. came out pretty good.
Dano
That really came out good! Looks great!
-Dan
Desert Rat
2017 Frontier 4.0
2008 Boulevard C90T
sorta...there's a custom brent 1/4 stock bracket that bolts to the end of the bumper into a welded nut and endcap, and goes down and bolts on top of the body mount. It's not the most stable thing in the world, but it will allow me to use a hi-lift on the front of the truck. It would need substantially more gusseting if I were to add a winch.
houdini
thanks desert rat. i had been thinking about and talking with richard about bracing back to the body mount as well.
i am also thinking about running tube from behind the lower outer portion of hte bumper back through the wheel well (keeping it high and tight) to connect to the frame behind the tire or basically under the seats. could then maybe use the tube through the wheel well as a shock hoop mount for the eventual sas.
just a thought.
thanks.
Desert Rat
2017 Frontier 4.0
2008 Boulevard C90T
That's a good idea...tie it back into your slider and use it for fender protection in the trees. A reinforcement down to the frame ahead of the wheel would double its strength.
White_Shadow
nice bumper! but i am not into the offroading
jdmfreak
DAMN! Thats just sick! Im not really a truck guy but slowly Im being converted...
houdini
finally got the center plate installed! let me know what you think.
didn't end up using stainless. the guy with the shear said he could not do it. said he would need a bigger shear, but did go ahead and shear off a piece of aluminum. Freebie! (thanks for handling everything richard!)
i orginally installed the aluminum plate without any holes. just the full plate. it looked good, but i found out a couple of days later that it wasn't going to work. ~70mph on a 95 degree day with the AC on max and the truck started to overheat. i guess no air flow through the skid and 4 hella's up top just wasn't going to cut it.
so....1.5 drills and 24 hours later it has 4 new holes. i think it looks better than it did without.
hope it works well. i don't see why it wont. gotta pull everything this weekend....wire wheel the bumper again and clear coat again. shouldn't take too long, but its a pain the ***!
here are the pics.
later.
Mr. Plow
Car: Silver '06 Frontier KC Nismo
Like I said on CF, that's Billy-Bad-A$$!
