IvanAtSPRacing »
https://forums.nicoclub.com/ivanatspracing-u15633.html
Sat Nov 06, 2004 7:06 pm
I got two blocks back from the machine shop and started assembly today.
Arais pistons, Shotpeened factory rods with ARP BBC bolts (circled), Clevite bearings.
Micropolished crank, main girdle, rebuilt reworked front cover with oil pump.
Bored, honed w/ deckplate, painted block.
Surface decked for Cometic gasket, brass oil port pulled and tapped for plug (circled)
Notice the factory piston squirters reinstalled, Clevite bearings with assembly lube.
Crankshaft nicely tucked into place.
Electric ring filer, feeler gauges, etc
I got the block, crank, main girdle all ready to go. Popped the oil squirters back into the block after blowing them out well. Installed the bearings in the block and lubed them up. Layed the crank into place. Installed the bearings in the main girdle (dry) and plastic gauged the mains. With just a polish on the crank and the main crank bore untouched, the oil clearance was exactly what I wanted (.002") all the way across. Once I cleaned the PG off the crank and bearings, I lubed up the lower main bearings and torqued the girdle into place. The crank spins like butter. No rough spots.
I checked ring gaps and found the top ring to be too tight for my liking so I spent about 1/2 hour filing the rings to fit. The Bottom rings were fine from Arais for a boosted application so I didnt have to file them. Thats about as far as I got today.
Monday I hope to get the entire rotating assembly together.
I will keep you updated
