Programming instructions - keyless entry
Post all your Nissan electronics, car audio and stereo questions here!
Q
Car: J30
I lucked out and found a fob on ebay for my J30 for $22. I was told there were simple instructions on how to program a new remote to your car. I figured I'd try here first.
TIA for the help.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Q
Car: J30
I tried as per the instructions you posted. No go.. even with a new battery.
Are there any other steps I need to take before I try again? Windows down? Hood open? Headstand while eating a pickle?
The stealership said they'd charge me $45 to do it for me, but I know the instructions are out there somewhere. Anyone have any ideas?
Rex
Car: None
I know I'll sound like an idiot, but be patient and try again.
Are you sure the remote matches the FCC codes for you car?
Q
Car: J30
Some questions on the instructions. Forgive me for asking these anal questions.
While sitting inside the vehicle:1. Open the trunk. 2. Close and lock all doors. Manually or with the drivers panel?3. Insert and remove the key from the ignition six times within 10 seconds. Do I need to turn the key or just insert/remove it?4. Manually unlock and lock driver's door once to enable "setting" mode.5. Push lock button on the new remote controller once, just long enough to hear it beep, within 5 seconds of completing step 4. How long should I push the button? Press and hold or just one quick push?
Thanks again for the help guys.
