djwarner »
https://forums.nicoclub.com/djwarner-u152452.html
Tue Sep 06, 2011 9:45 pm
OK, you dragged me out to the car to retreive the Owner's Manual. See page 3-20
0. (my step) with the key in the ignition set to LOCK open and close the driver's door at least twice.
1. Check the transmission is set to PARK.
2. Turn the ignition to ON (engine not started).
3. Adjust the seat, rear view mirrors, and steering column.
4. PUSH the SET switch ( I believe both lights for 1 and 2 will come on and then go out).
5. Within 5 seconds of pressing SET, press 1 or 2 for at least one second. The selected memory position light will come on for 5 seconds and then go out. After the light goes out, the memory is stored.
When you turn the key to off and remove it, the wheel should move up and the seat should pull back.
To change from pre-set position 1 to 2 or 2 to :
1. Check the transmission is set to PARK and the ignition is off.
2. Turn the ignition to ON (do not start the engine).
3. Push the desired pre-set position 1 or 2 for at least one second.
The automatic drive positioning will not work under the conditions outlined on page 3-22.
If all else fails, go to page 4-7, de-select the lift steering wheel and adjust driver seat options. Then reselect them and try to set the memory again. If it still fails, reset to factory defaults again.
To confirm a memory is stored, turn the ignition to on and press the SET switch. It there is no memory stored, the indicator lamps will come on for a 1/2 second. If a memory HAS been stored, the lamps will stay on for about 5 seconds.
