For future reference - since I've seen people CHARGING $$$ for this information (just sucks, IMO
I just (and I mean literally just minutes ago) programmed my eBay FOB with the instructions from this site:
http://www.programyourremote.com
If for some reason this company goes under:
IMPORTANT: Before entering programming mode, have in possession all of the transmitters
you will be using on the vehicle. Once you program the transmitter, all previous codes will
be erased from the memory. The other transmitters will not be functional until you program
the transmitters again.
1. Close and lock all doors with the driver’s side power lock/unlock switch.
2. Insert key into ignition and remove it from the ignition key cylinder at least six times
within 10 seconds. Your Hazard Lamps will flash if you have performed this step
successfully. NOTE: Withdraw key completely from ignition cylinder each time. If this
procedure is performed too fast, system will not enter programming mode.
3. Insert key into the ignition cylinder and turn to the ACC position.
4. Within 5 seconds, push ANY button on the remote transmitter. Your Hazard Lamps should
flash. NOTE: Do not press the button more than one time in the above step. If the button
is pressed more than one time, the programming procedure will not be successful.
5. If there are any remaining transmitters (including the old ones), unlock then lock all doors
using the driver’s side power lock/unlock switch and within 5 seconds, push ANY button
on the next remote. Your Hazard Lamps should flash. Repeat this step for each
transmitter (including any existing transmitters).
6. Turn the key to the OFF position, remove keys from the ignition, unlock doors using the
driver’s side power lock/unlock switch and open the driver side door.
and the obligatory "disclaimer"
Disclaimer
1. ProgramYourRemote.com does it best to make sure the information viewed on our website is
accurate. We will not be held responsible, however, for technical inaccuracies or typographical
errors.
2. ProgramYourRemote.com shall not be held liable for damage or loss due to your use of any
programming procedures used from this website.
3. ProgramYourRemote.com does not make any warranties about the procedures listed or about
the accuracy of the programming procedures.
4. ProgramYourRemote.com, accepts no responsibility for content, or other problems that may occur
from the use of the programming procedures used from this website.
... and I also take the same disclaimer: Not my fault if it doesn't work out for you
