Program remote on 2000 Q45
doublesharp
I did a search first but found no info on y33. Is it the same procedure as for a 96 Q? I've got a 2000 Q and I want to program a second remote. Thanks
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Let me search my TSB, but right off hand I don't recall seeing a procedure for the FY33. Do you have a Service Manual? Check back later.
doublesharp
No, i don't have a service manual. I do have Owners manual but I found nothing there. I bought car from a wholesale dealer and it only had 1 remote. He promised me another and he came through but it's not programmed. Thanks for looking.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
From page EL-348. Additional Procedure using Consult II on EL-349-350.
MULTI-REMOTE CONTROL SYSTEM — IVMS
ID Code Entry Procedure
Enter the identity (ID) code manually when:* remote controller or BCM is replaced.* an additional remote controller is activated.
ID Code Entry ProcedureTo enter the ID code, follow the procedures below.
PROCEDURE 1 (Without CONSULT-II)
1.) Close all doors and lock driver side door.
2.) Insert and remove the key from the ignition more than six times within 10 seconds. (The hazard warning lamp will flash twice.)
3.) Turn ignition key switch to “ACC” position.
4.) Push any button on the new remote controller once. (The hazard warning lamp will flash twice.) At this time, the new ID code is entered and original (previous) ID codes are erased.
5.) Do you want to enter any additional remote controller ID codes? If YES, got to 6. If NO, go to 7. A maximum four ID codes may be entered. Any attempt to enter more will be ignored.
6.) Unlock and lock with the driver’s lock knob switch. Got to 4.
7.) Open driver side door and remove the key from ignition key cylinder.
8.) END. After entering the identity (ID) code, check the operation of multi-remote control system.
NOTE* If you need to activate more than two additional new remote controllers, repeat the procedure “Additional ID code entry” for each new remote controller.* If the same ID code that exists in the memory is input, the entry will be ignored.* Entry of maximum four ID codes is allowed and any attempt to enter more will be ignored.
doublesharp
Worked like a charm. Thank you very much.
