program automatic door locks
Discussion forum for body kits, repair, modifications, interior styling, Audio / Video and internal/external lighting.
luxurycarg37s
Car: g37s coupe
i have a 08 g37s and i can not get the doors to lock after driving over 15mph or whatever speed the doors are supposed to automatically lock is the owners manuel says to put the car in the on mode which and press and hold the lock buttton for five seconds and the flashers will flash indicating that the doors are programed to lock after driving i have tried that and i does not work i have also tried doing it in acessory mode with the car running and with the car off with the doors open and the doors shut .... am i doing something wrong ?
bersh240
we. the 240sx owners.are way to poor to own a g37.wrong section buddy..
go here. g37 forum..http://forums.g35club.org/
ILoveMyRHS13
Car: 1990 Nissan 240sx (Hatch)
Go to the dealership and ask?
joe603
Car: 2014 Durango R/T
You should be able to turn the option on in the AV console unit. I don't remember the specific term they used, but it should be there.
edit: looked at the manual and it's only for selective door unlock and intelligent key unlock settings.
You have to perform the methods listed below to turn off the automatic door lock.
cjs37xs
Car: '09 G37xS
Ask Manuel...he's so smart! He knows everything...especially manuel who is all knowing for the G37. He likes to live in your trunk....in a little black zipper pouch. He goes by the name "owner's manual".
Here's what he told me: look in chapter 3 Pre-driving checks and adjustments section 3-6 "Automatic door locks".
Now, I truly recommend looking for it yourself, as you may need this to follow the instructions. But, being the nice person I am(also being bored as hell today anyway!!), and since I already went to the garage to get my manual out of the trunk...here you go -
The automatic lock and unlock functions can be deactivated or activated independently of each other. To deactivate or activate the automatic door lock or unlock system, perform the following procedure:1. Close all doors.2. Place the ignition switch on the ON position.3. Do one of the following within 20 seconds of performing step 2: * To change AUTO UNLOCK settings: push and hold the power door lock switch to the UNLOCK position for more than 5 seconds. * To change AUTO LOCK settings: push and hold the power door lock switch to the LOCK position for more than 5 seconds. (This one is YOU!! )4. When activated, the hazard indicator will flash twice. When deactivated, the hazard indicator will flash once.5. The ignition must be placed in the OFF and ON position again between each setting change.
And there you have it - verbatim from the owners manual - (minus my little parenthesis) This should get you on the right road....now to find that section about setting your memory seats to your key fobs!!
luxurycarg37s
Car: g37s coupe
lol thanks i already read that part and tried it here are the ways i tried
1 got in car closed doors press start button twice to get to the on postion and within 20 seconds press and hold the lock button in the lock postion = nada
2 did the same thing but held the lock button in the unlock postion = nada
3 tried the same thing with the car in accessory mode =nada
4 and tried the same thing with the car running
i dont know maybe i am still missing something or my automatic door lock is broken
Return to “G35 and G37 Interior, Exterior and Audio”
