DrifterProdigy85 »
https://forums.nicoclub.com/drifterprodigy85-u30257.html
Fri May 26, 2006 3:21 pm
you guys run with some crazy numbers, it makes me wonder if you know what your setting. Theres 3 control settings. Set Boost, Gain, and Start Boost. Set Boost - increases boost. Gain - Stabilizes boost. Start Boost - holds the wastegate shut creating quicker spool. I dont use the Start Boost feature because it makes the turbo boost funny when trying to control boost with the throttle (road racing). Use the Set Boost feature first for the desired boost and use the Gain feature to stabilize if boost drops off at high rpm or creeps. With my T25, i had 15psi set up like Set Boost 50% and Gain 14-16%. With my 2871R, 15psi is Set Boost 40% and Gain 7-9%. Theres no need for the Gain to be up real high unless your trying to compensate for boosting problems.
