profec b-spec 2 help
corey240
Car: 1993 Nissan 240SX Base Drift Machine
ok i have walbro fuel pump,3" greddy exhaust system and down pipe,intake,greddy fmi,hks bov,dual 12" fal fans just the basic things and no other fuel upgrades or turbo. my question is if anyone has a greddy profec b spec 2 if they would tell me what to set my stuff on so my engine is safe. thanks.
wildacexxx
Car: 2002 Q45 nav sport
do u have a boost gauge? a profec b is just a boost controller and u need a boost gauge to set a safe amount of boost.
SuperScooby
actually, you need the boost gauge just to verify that the boost controller is doing its job (by reading the current PSI)
unless if that's what you meant
S13240
The profec b spec II has a digital boost gauge built in. The thing I hate about the Spec II is that it spikes/creeps a lot especially with weather change. Tuning on it sucks. My selenoid took a crapper on me after three months!
But set it to 12 psi which is .80 and 1 bar for the other setting and you should be cool. The other tuning options are pretty much up to you. Test and tune buddy.
Modified by S13240 at 3:58 AM 2/14/2006
corey240
ok thanks alot i set it to that today.
luv2spedup
Car: 89 silvia
there is also a way to set it in psi i have one to i'll check it some time today and let u know how to set it in psi
