productive "maintenance" day
HeavyDuty
Car: 1995 Infiniti Q45
95 Nissan 240SX S14
96 Nissan D21
06 Nissan 350Z Z33
Several more items checked off the list (installed) on my 91 today;
Eibach Pro-KitsTokico Bluesupper linksstrut mountsdust boots / bump stopsnew driveshaft (indexed, thank you very much) :D
ahhhhhhhh very nice.
think the wife will notice?????????
"nah honey, it just looks lowered because your Pathfinder sits so high." :rolleyes
DAEDALUS
Car: 1990 Infiniti Q45
Damn.... I would've gotten to the driveshaft and said "tomorrow's good enough". Surprised you're not raving about the new struts and rubber in there.
Altiman94
Car: 1989 Nissan 240SX
Sounds like it was a very productive day. Give us some feedback on the newly installed suspension
Checkered-Member
Car: 1998 Nissan Altima (modded)
2003 Audi A6 2.7T (stock)
HeavyDuty wrote:think the wife will notice?????????
:D haha for some reson i find that very funny
HeavyDuty
95 Nissan 240SX S14
96 Nissan D21
06 Nissan 350Z Z33
The driveshaft *should* have been easy, Daedalus, had it not been for the center bearing being so bad it caused a stress fracture in one of the retaining studs, so it broke when we removed it. Had to cut the boss on the floorpan, weld in a new stud & weld back up & grind & paint.
Suspension is so nice & quiet, not rough at all, front camber isn't out of spec enough to warrant camber kits, rear is adjustable. Toe is out but I'll take care of that next week.
However, as Q45Tech mentioned earlier, the driveline vibration has caused excessive wear in the pinion bearing, so some noise is still there, but the vibration is gone, thank the Lord.
I'll have my new (used) diff next week, I'm going to inspect that one, install it if it's ok & start a build up on my old one with slightly taller gears in prep for taller tires, ecu. tcu. 100 shot.
Well Done!!!
I'm impressed, HeavyD!!!
