One Crazy Max »
https://forums.nicoclub.com/one-crazy-max-u77654.html
Tue Apr 15, 2008 4:17 pm
Rear Endlinks: i was able to install the rear endlinks today without a problem. these actually took about 10 less minutes to install than the fronts, so i was correct in my hypothesis on difficulty. these endlinks, just like the ones in the front, are much more better than stock. they are beefier, adjustable to mount in many different ways, and they look a whole lot better. the rears actually have the racingline logo on them which is pretty cool. it probably took me less than 30 mins to install these, and probably wouldve been even faster if my arms didnt get tired from being up so long. these are also adjustable without removing them from the car.
Test Drive: well the addition of these endlinks along with the fronts made the cars handling improve even more. driving straight, i tossed the wheel side to side to see how the car would react, and there was no delay in movement. everytime i pointed the wheel where i wanted to go, it went there as soon as i turned it. the car feels even more connected now from front to back, and side to side, and it feels even more planted to the ground that with the Front endlinks, and those were a drastic change as well. this is another mod i would suggest to you all as well. i was not able to take the car through turns yet, but i will tommorow when i got to school. i already know that i will feel the difference on the hwy on-ramps.
another thing to note...with all 4 endlinks installed there is less wheel hop, which is a great plus. that means more traction :
soon to complement these two mods, i will upgrade my tires to a stickier compound in order for the car to feel even more planted. also i am looking to upgrade the rear sway bar, which is connected to the rear endlinks, to a bigger one, but i have to do some research still, i was thinking about using the 26.5mm SE-R RSB since the 02+ Altimas are using similar Rear suspension setups. im not sure yet, but those mods will sure make the car handle even better than it is now. and then later on down the road, i will upgrade my springs/struts to stiffer components.
here are the pictures of the rear endlinks, stock and racingline ones.
racingline rear endlinks
stock endlink(left) vs. Racingline Endlink(right)
stock endlink installed
Racingline Endlink installed
these should most likely fit the coupe as well. the suspension setups on both cars are not that differentcontact "taz" for more info regarding info on these and other racingline products. +1 for a great product and vendor.
