I second that, shiming the wastegate is the a good upgrade (power VS. money).
I use this method for a year now and i like the fact that this modification is nearly unseeable.
On my setup (stock T25, Saab IC, K&N, CA16DE intake cam, 2.5inch exhaust, no cat, stage1 chip and walbro pump) i run:0.8bar (11,6psi) without touching the wastegate0.9bar (13psi) with a 0.5mm washer set1.0bar (14,5psi) with 1,5mm washer set
Btw totally stock my car had 0.6bar, exhaust/filter gave an extra 0.1bar and the intercooler also.
