White Comet »
https://forums.nicoclub.com/white-comet-u42048.html
Fri Dec 19, 2008 6:55 pm
this thread could probably go in gen chat but i thought a 240 owner could get good use from this product like I did. A few months ago I purchased the duplicolor brand truck bed coating kit. The kit can be picked up at most parts stores (i went to advanced auto parts) for about $60. The kit is intended to coat the bed of a truck so that it can be used for hauling items without scratching the paint. The kit contains a brush, scotch brite pad, roller and the "paint" (if you could call it that). the paint dries very hard and is resistant to scratching and chipping. the most important part thoguh, is to give it AT LEAST the recommended coating of 5mm. after only one coat it is still a very thin layer and can easily be scratched or chipped. after a few more coats for a nice thick layer it very tough and durable. I used this product to coat the under side of my car as well as the wheel wells to prevent and rusting or rotting of the frame. the car hasn't been driven yet, but since it's my daily driver it'll go through the snow and salt and other bad weather conditions, so i will update then with how it holds up over time. In the past i used a spray on rubberized undercoating, and wasn't entirely happy with the results. Even after a liberal coating, it eventually wore through and it dried soft and mushy kind of, where as the truck bed liner dries very strong and hard. For applying the material, i found its best to just get a cheap set of brushes, seeing as the roller didn't work to well for me. As long as the surface is clean and scuffed up with the scotch brite pad, it adheres nicely and goes on easily. For getting in hard to reach places, dupli color also makes truck bed coating in a spray can, its very similar to the brush on kit i used, but since its the spray form its a little thinner. the Actual kit works nicely since I can brush on nice thick coats. I woudl highly recommend this to anyway looking to prevent rusting on the car's underside. It's a stronger material then the runny spray can stuff, but cheaper then some other alternatives.
Here are a few pics of the progress of coating my under body
here's a short video where i take a grade 8 bolt and try to scratch a frame rail coated with truck bed liner, that has dried for the proper amount of time. I did this to show the durability.
If you have any questions let me know, i just thought i'd share this with everyone
