jerryd1987 »
https://forums.nicoclub.com/jerryd1987-u188669.html
Thu Feb 14, 2013 3:35 pm
i wouldnt do twins due to the cost honestly, look into boosted performance his precision 6266 kit will handle 600 to the wheels easy, and also offers 6766 and 7675 kits to support up to 1k. not sure on the 7675 but the 6266 kit will cost about 5200 or so for the stage 1 tuner kit, stage 2 with the 6766(this turbo is making 900 on supras the closest thing we can compare too, i make 600 on lowboost havnt dynoed with it turned up to 32 psi yet still breaking in the new clutch) is about 5500. i talk the kit up alot but it performs and is excellent craftsmen ship, even if it wasnt sasha's customer service alone would have me raving still, best way to build a cult like following is good cs.
it will also never scrape despite being mounted under the car, of all the kits he has sold im the only one to have any piece scrape the ground, and thats because the wastegate tube is supposed to be angled to the back of the car and i have it angled toward the ground, if i put it on properly it wouldnt be a issue i just prefer a open dump blasting out the side of the car instead of right under my seat, recirc wouldnt be any issue at all.
if you insist on keeping the procharger(im making a educated guess your running the t trim) then a brace on the front of the case will help a little bit, as well as a crank brace(big a** bar that bolts to crank pulley and supercharger pulley) then you might be able to get away with it but your going to have alot more wear on the super charger bearings as well as your front crank bearing. 10 rib setup would be only real solution though i know you can get them that fit the accessorys i think someone priced it before and would be like 1500 or something for a 10 rib setup. you have a fluidamper or ati crank pulley?
personally i just think its way to much money or work for minimal power output, i have 28k into mine and will support 800+ to the wheels with several components supporting 1000+ only limiting factor being stock sleeves limiting me to somewhere between 744 and 880 rwhp and turbo limiting me at somewhere between 850 and 900. coulda redone it for 24k or so for the same power level or about 25k for 1k to the wheels if i dint do the custom stuff i did.
admittedly you prob end up spending more paying someone to do it though, i built mine on jackstands in my parking lot(ok well parking stall i guess you would call it)
