Timothy S »
https://forums.nicoclub.com/timothy-s-u242199.html
Sat Nov 29, 2014 7:28 pm
I replaced the timing chain in my 98 altima a couple years ago. You can remove the upper and lower timing covers after removing the valve cover and aluminum oil pan. No, you cannot remove the lower cover without removing the center frame member and two center engine mounts to drop the oil pan. You can replace the chain at this point and the only reason they tell you to remove the head is to install a new head gasket. If you dont break the old gasket or are willing to take the risk, you can use rtv sealant around the head gasket between the upper and lower timing covers and just put everything back together.
Timothy S
1998 Altima with 129k
