Procedure for Flushing the Fuel Rail
firstq
Guys - take a look at the following URL, and let me know if the setup & procedure listed below is correct for flushing the fuel rails.
http://members.cox.net/azheer/Presentation2.ppt
1. Remove the fuel pump fuse and run the car until it stops. crank 1-2 more times2. route the setup as listed in the above diagram3. set the pressure on the regulator to 35 PSI4. Start the engine (with fuel pump fuse removed, right?)5. Maybe upping the PSI upto 50 (for some time) for thorough cleaning6. Let it run until it dies again7. clean the return hose catching the gunk [if any]8. Reassemble and drive hard for 15-20 mintues9. put 44k in the tank with maybe 5-10 gallons10.. Fuel filter is relatively new (may be 3k miles) - hoping I would not need to replace it.
Anything to change?
