probs with my 90 SOHC
DALAZ_68
Car: 90' 240sx CA18det
hey guys...
i own a 90 240 with stock KA
iv simply put the ****in thing wont start...it cranks over... ive replaced the fuel pump,strainer, and fuel filter...has plenty of fresh oil...plenty of spark...just changed the coil too...
wut the hell could it be, the parts replaced are pumping plenty of gas, the pump is priming fuel,
guys i need help this thing is my means of transportation, any one isn socal willing to come down for a beer and help me out, please **tear**
i have AIM whopperbb
Modified by DALAZ_68 at 10:47 AM 7/9/2007
240RB1
Car: 03 Infiniti G35
92 Nissan 300ZX Z32
95 Jeep Grand Cherokee ZJ
check your coolant temperature sensor its on the intake manifold twords the front. this happened to be a while back so hope it works for you man.
DALAZ_68
but...its not hot, it front a cold start...but ill check it if u can give me a pic of it...?
but how would a coolant sensor have to do with it if its a cold start?im not tryin to sound like a prick i hoenstly dont knoe... i apoligize if it sounds like im tryin to be a smart *** honestly
240RB1
92 Nissan 300ZX Z32
i really dont know what it has to do but it worked for me its between the manifold and the head it is usually a gold probe with a red top
DALAZ_68
i cant see anything wrongt with it, it doesnt look burn out or anything...
240RB1
92 Nissan 300ZX Z32
they dont look burnt or worn infact they look new becuase the wetr antifreeze are constantly cleaning it they just fail overtime go to a junkyard and get a couple or buy a new one thats what i did it was somewhere around 16-17 dollars
DALAZ_68
damn, well i needa find more trouble shoots...i dont have a car to go the yard rite now lol
240RB1
92 Nissan 300ZX Z32
this probably wont help much but who knows when my car wouldnt start befor the sensor while the car was hot we searched and found thet the fuel pump relay didnt work ,it would prime the lines but would give out once it tied to start and we replaced it and the sensor and ive been beating the s**t out of it since then with no problem.
DALAZ_68
i mean i could only see it being a problem if it was hot, but it isnt...the thing is cold (the car) but i guess it might be a sensor sayin this doesnt work dont let car start kinda problem... and i i dont have an engine light either...
240RB1
92 Nissan 300ZX Z32
try these things and see if they check out or nothttp://www.nicoclub.com/articles.php?id=160218
DALAZ_68
ok i checked the gas flow...i disconnected the line that feeds fuel to the filter to the fuel rail, and it comes out in squirts, wut could that mean...i knoe it might mean not ebough fuel at once to cause proper combustions, but if the fuel pump is pumping, wut could cause the low fuel flow?
DALAZ_68
any one in socal near L.A. (close to dodger stadium ) willing to come down and look at my car for some beer lol
DALAZ_68
i wanna take apart the injectors to see, but i need pics for help...
neverlift
dont **** with your injectors... was the car running before this happened?
check your ecu for codes.
it will tell you if your cts is bad(should) mine does(stanza ecu)or if you own an ohm meter/multimeter you can check it that way as well. stop buying stuff. DOes your tach move when trying to start. Again a code check would tell you this.
DALAZ_68
well i didnt mess with the injectors, i just read the troubleshoot list and it said to check em ...but i havent...yes the car was running normally just yesterday...
no the tach doesnt move when tryin to start
were can i get a code check, i dont have money to tow this things around...or were can i rent one? but isnt the 90 a pre OBD car?
Modified by DALAZ_68 at 8:27 PM 7/9/2007
neverlift
you check them yourself. remove passenger kick panel use a 10mm socket and extension to lower the ecu,put car to start but not fire,insert small flat head and turn the screw it says which way on the ecu....
your gonna have a 21 IIRC your primary ignition signal. I'd start with a junk yard ignitor. IF thats not it(and your coil is good) look into a dizzy. sorry for your luck
DALAZ_68
well finally fixed it...it was the hose of the fuel pump... it tore, simply put i was getting gas...
freakin aye
nismoracingsx
Car: 1993 White 240sx Coupe
at least you fixed it in a day, good job mang
DALAZ_68
sad part is now im even deeper in debt then b4, and my timing chain is looser than a hooker on hollywood streets
and i dont have enugh for the timing kit
