the reason the dowel pins are missing on the ebay piece is because it was turned/resurfaced and they didn't press the pins back in. I could have the pins pressed out but I'm worried that the PP might get off centered (either when bolting or by rotational inertia) and then cause the assembly to be unbalanced = bad. Spec's PP doesn't have a close enough tolerance on the holes to solely use them to center the clutch, either.
robdet-- mine are way more off then that. I've tried every position on the PP and only one way lines up the flywheel bolt holes to the PP bolt holes. But when you have that position the pins are so far off that you can't bolt down the PP, it'll just bend. When I installed my fidanza flywheel on my G20 I had a similar problem to you, the PP wouldn't slide on, it needed help.
anyway when I tried, it was late a night so I'll give it a try again.
thanks for the replies.
