szh »
https://forums.nicoclub.com/szh-u149.html
Thu Oct 25, 2007 9:17 am
It is normal for tires to drop 1 to 2 psi per week or two. Even if the weather does not change perceptibly. It is more than that for weather changes.
I would strongly recommend getting a good tire pressure gauge (analog or digital ... I have a very accurate resolution 0.1psi gauge from Accutire, but this is overkill) and check your pressure every week (during weather changes) to every other week (when the weather is relatively unchanging). The car TPMS should be treated as a measure for avoiding dangerous low levels only - "red light" functionality, even though you do get readings!
Remember to measure the pressure cold, in your garage, before the sun hits the tire in the morning, (meeting these objectives within reason, of course ) and adjust the pressure to all the correct values on all tires.
BTW, somewhere near 36psi +/- 1 or 2 psi is the right range for almost every tire I can think of, for our M's! This allows for gauge inaccuracy (particularly important for low aspect-ratio tires), a normal drop during the week to stay safe, normal wear and tear, etc., etc., etc.
Z
