kridgleyud »
https://forums.nicoclub.com/kridgleyud-u87158.html
Tue Jun 03, 2008 2:28 am
I havnt seen much in on topic of 1st year problems the Rogue is having. So I will share what I have experienced.
1st, I was hit in a parking lot, not Nissans fault but was the first problem.
2nd, My Speedometer would get stuck after interstate drives (intermittant), sometimes would 'zero' at 25mph so that 30mph was reading was 55mph. This was never fixed at nissan, I just kept getting the "we cant reproduce this" answer from them ... three times now.
3rd, small leak in tire, caused my a nail - simple fix.
4th, while fixing 3 above, jack buckled and dropped the car, so LUCKY the tire was still on. I live in Delaware where there are no hills, and it was done in a parking lot ... contrary to what nissan believed, it just gave out. if you look at the jack you can see how cheap they are. This was replaced free of charge.
5th, Severe braking at 40-50mph, dealer told me it was because of warped rotors. This happened at about 8000 miles so I was furious that the factory rotors only lasted me that long. Started arguing at the dealer and it turned into all front end brake parts replaced and sent back to nissan.
6th, still experiencing freezing speedometer and a few nights ago the tach got stuck at 3000, would not go up when accelerated - reset and did not go away. Same answer from nissan - no fix.
7th, the stereo - tried to load a CD into dock 2 and waited for load CD message, loaded, it spit it out and made a bunch of noise and then read "temp/mech failure". Now i can not select the CD source, try to cycle thru on the steering wheel and it skips the CD source, i just get the 3 radios. Calling nissan today .......
None of these with the exception of the brake parts were very serious, but my car only has 11,000 miles and Im starting to worry that it may not make it 100,000. i still like the car, but these problems are frustrating.
Thought i would share that there are some glichy rogues out there and i hope i am the only one.
kev
