Postby
Buck01 »
https://forums.nicoclub.com/buck01-u138865.htmlSat Aug 08, 2009 6:02 pm
Hey Guys I'm New Here But have A 1996 240sx SE, it Has 157,101 Miles On It And I Just Did a Tune Up. I Replaced The Fuel Filter, Plugs And Wires, Distributer Cap and Changed the Oil....But I'm Noticing A Slight Stuttering In the Throttle, When I Run The Car Sometimes It Starts Bogging And Stuttering For a Second But Then After It's Fine. Do You Guys Think The Fuel Injectors Need Cleaning? Let Me Know Thanks.
Postby
Salem240 »
https://forums.nicoclub.com/salem240-u105033.htmlSun Aug 09, 2009 3:23 pm
does it only do it after the motor warms up and/or drive it for more than 5 min? I've prob got the same issue. I posted it in the tech forum and even included a vid today.
Postby
Salem240 »
https://forums.nicoclub.com/salem240-u105033.htmlSun Aug 09, 2009 4:03 pm
Let's see...... I've replaced the fuel pump, front o2 sensor, throttle position sensor, spark plugs, distributor cap, rotor button, wires, pcv valve ( a PITA) and fuel filter. I've cleaned the mass air flow sensor, air intake temp sensor, throttle body, seafoamed and injector cleaner. I even changed out the ECM. I can't find a solution
Postby
YuNg1's_240sx »
https://forums.nicoclub.com/yung1-s-240sx-u69711.htmlSun Aug 09, 2009 6:05 pm
did you guys check for cracks at the ends of the wires??one of mine is cracked and and it had a slight leak of fuel...maybe this. But i have a feeling it could be the valves also, but im only slightly educated in the top end of motors.-Arash
Postby
YuNg1's_240sx »
https://forums.nicoclub.com/yung1-s-240sx-u69711.htmlMon Aug 10, 2009 11:13 am
hey good call. 240sxFTWhttp://forums.nicoclub.com/zerothread/159907http://forums.nicoclub.com/zerothread/216236there is another problem i have though, my car doesn't start all the time. Now im guessing there is a ground on the starter that is causing this.what would you guys say?-Arash
Postby
WutsDrift »
https://forums.nicoclub.com/wutsdrift-u125267.htmlMon Aug 10, 2009 1:00 pm
My 14 does the same thing. I went to Auto Zone and got them to run a free func check on it cause my engine light is on and I got an O2 Sensor malfunction so you might wanna check that out or you could have a problem with your MAF.
Car: 1989 240SX Coupe 5sp SOLD 1989 240SX Hatch auto SOLD 1990 240SX Coupe auto WRECKED 1990 240SX Hatch auto 1990 Jetta Turbodiesel 5sp FEILD BAGGED 1997 Jimmy 4WD 1985 Chev Wrangler 1994 F150 4X4
Postby
YuNg1's_240sx »
https://forums.nicoclub.com/yung1-s-240sx-u69711.htmlMon Aug 10, 2009 2:46 pm
hmmm. It might be that O2 sensor for me because ever since my exhaust broke, its been doing this. But i think for me, my best bet would be to get the exhaust replaced in the first place, then we will move on from there.
