Problems with starting've
dedoslav
Hi everyone!
I've bought a Versa couple of months ago and I already have a problem. Last weekend I couldn't start my car. When I turned the ignition on all the lamps came on as usual, but when I tried to start the car the starter didn't make any sound. The battery seemed to be fully charged, all the electrics seemed to be working OK. I checked the fuses and they seemed OK also. I was with my friends, so we push started the car (nice to have a stick shift) and it worked OK. When I was getting home from my friends' the same thing occurred, so we push started the car again and I drove home. The next day I tried to start the car and it started flawlessly! It's been two days since then and it starts and drives just fine. Can anyone tell what was it?
Modified by dedoslav at 5:19 PM 3/27/2007
CodeRed
Car: 2008 Nissan Versa S MT
No idea what it could possibly be, but seeing how it is starting fine now nothing should be wrong, anyways stop by your nissan dealership and get it looked over and tell them exactly what happend. Coud be your altinator?
dedoslav
CodeRed wrote:Coud be your altinator?
Well, the alternator just recharges the battery, and from how the electrics worked I'm sure that the battery was charged. If the charge is enough for the starter to work, then the alternator is not even needed to start the car. Since the starter didn't make any noise at all, it seems that the current just didn't reach the starter. The question is why.
CodeRed
lol, yeah your right. I think the real question is why havent you contacted your dealer :P prolly some short, or somthing idk
dedoslav
CodeRed wrote:I think the real question is why havent you contacted your dealer :P
Well, I have contacted the dealer, but you know the people that answer the phone calls at the service dept. don't know a **** about cars, and the guys who know something are always busy. I'm a little busy now, don't have time to go to the dealership. I just thought that somebody on this forum might have similar problem.
Ever Victorious
Car: '08 Kia Spectra 5
'73 AMC Hornet
Not with the V specifically... but that sounds like a starter or starter solenoid problem.
joaopinto
Car: 2007 Nissan Versa
Stupid question: Since you mentioned you have a stick, did you pressed the clutch pedal when you had the problem with the engine not starting?
proxim2020
joaopinto wrote:Stupid question: Since you mentioned you have a stick, did you pressed the clutch pedal when you had the problem with the engine not starting?
That's not a stupid question and a good point. It's like when you're on your bike and can't figure out why the bike stalls when you put it into gear. After all those minutes of tinkering, you finally figure out the kickstand isn't up all the way
dedoslav
Yes I did. I know it won't start if the clutch pedal is not pressed.
Robi
Car: Maxima and Versa and a Suzuki Burgman
Trade it in on a Fit ... they start every time
weems84
Car: Versa SL
lol, i did that so much when i first starting riding. I felt like a complete idiot. My friends just kept pointing and laughing.
Jemdawg
Car: Super Black Nissan Versa 1.8SL Hatchback
Wow. I honor you for your honesty. I would not admit that if it happened to me.
