Problems with SAFC NEO. need settings...
memole
Car: 1993 240SX hatchback
Ok I did a search but didnt find anything that I was looking for. I did simliar searches on a couple other forums and still didnt find anything.... so here is my questions:
First my setup:
S13 SR Blacktop
S13 ECU Rom tune for Z32 maf and 550cc
I have the Z32 maf
550cc injectors
It was running pretty good after install. I was running into a decel air problem. I went and got a SAFC NEO to take care of that problem. Now I am having problems setting it up. I have had this proble for 2 weeks. the car will not rev past 2500rpms which would suggest a maf issue. I have checked the voltage to and from the maf to the ecu and back again. all that checks fine. I even changed out the maf for another one...still same problem.
SO... my question is what are the setting for the NEO. the instructions that came with it are horriable to say the least. first of all the wiring diagram they show is incorrect. the tach wire was mispinned in there instructions. I fixed that problem.
I have it set to 6in 6out. not even sure if thats right anymore. does anybody have ANY info that could help????
I got the NEO for fine tuning at the dyno but I can't even get it there. I was thinking about just takeing out the rom tune ecu and put my old ecu back in....but everybody says that I should keep that still use the neo for fine tuning. please if anybody has any clue of what might be going on please let me know. thanks in advance
Just me
Chris
inertiadrft
Car: Do NOT be fool'ed by the low post count, The wise choose silence over Bla Bla Bla...
try= single in / single out, at your own risk of course!! but that should fix not being able to rev past 2500 rpm's
memole
it is setting is single in single out... the instructions dont even tell you what that is.... doesn't rev past 2500 to 3000 dumping fuel like a b*tch and the plugs foul faster than I can put them in...
scotttak
Car: 2018 Camaro ZL1
make sure you picked the hot wire sensor under the options. i had the same issue and it turned out i was using the karman sensor setting
