xiongbs13 wrote:that is your tem. senser that could cause your car to not start at times and sometimes stall your car so it would be wise to change that out too
Yah, I replaced that first actually.
Anywho, problem solved. After reading some FAQ's and posts on 240sx.org I finally found something that helped.
So for those that can't find the answer to their problems maybe you should try this first:
While engine is running, pull 1 ignition/spark cable at a time, if the engine almost dies then the injectore/cable/plug is in good shape. If nothing happens, then inspect the cable (swap with another one and test again), plug and finally injector.
Apparently measuring 3 ohms on an injector is a sign of a failed injector, wish someone would of told me that sooner instead of me trying to check everything else. After 1 1/2hrs of trying to get the injector out, and a 20 minute trip to an autozone before they closed I had the new injector installed, hoses connected and fuse replaced with a VERY smooth running car. All this just to drive it 1 or 2 more days before I get the swap done. God I love this car.
Oh yeah, if anyone else plans on replacing the Engine coolant sensor, make sure you have something to catch the coolant that comes out of the hole (oops, kinda forgot that part).
Thanks for all that helped (xiongbs13)
