problems with my steering / what is wrong
rgnissan240sx
Car: 1991 NISSAN 240SX
Hey guys im having trouble with my steering before I start a turn my steering. Wheel is perfectly straight and after I exit the Turn my steering wheel is no longer straight the real problem starts during high speed turns this will happen and want to over steer with little and sometimes it understeers. Does anybody know what is wrong with my car any feed back will b great thanks
Lobo240sx
Car: 1991 Nissan 240sx Coupe SR2.35DET Redtop Build
I'd start off by checking your steering knuckle on the power steering rack. Make sure it is tight. Your car might need an alignment if you haven't had one recently. Check the power steering fluid in the reservoir. Tie rods could be worn.
rgnissan240sx
Thank you for the insight I apreciate it
ricebike
2002 Quest
2005 Altima
don't forget to look at the steering rack bushings
