Problems with my ka24e
hellzknight
I cant get it to idle right
I have removed the upper and lower plenum and replaced both gasketsRemoved the EGR Vavle and the Butterfly valves. Both Blocked offRemoved the lines that ran down the middle of the manifold. All are capped offRemoved the B.P.T ValveRemoved Pressure regulator control solenoid valve and SCV control solenoid valveRemoved A.I.V CaseReplaced MAFReplaced Distributor with a New cap and rotor and wiresReplaced I.A.A ValveNew o2 sensorRelocated the battery to the trunk
There was a lot of resistance in the fuel pump assemble i redid the wires and now its fine, it wont start. I then replaced the distributor.
Now here is the problem its hard to get the car started. I have warm up the engine before the car will stay on, but it floats around to much :/ I think that the Air Regulator valve is bad.
Also i took the car to a shop a month ago and they sprayed carb cleaner every where, i had painted everything and the ruined all that....
They also sprayed carb cleaner in the intake =\
How can i test the air regulator and see if it functions? Also anyone else know what might be wrong?
mmaxeyjr
Car: 1995 s14
did you take apart the iacv and clean it?
hellzknight
the iacv is clean and running right i replaced it and it improved because it used to just stay at 2.8k now its gotten to around 1.1k but still floats
Razi
Car: Moo
Check all your vacuum lines.
hellzknight
no leaks that i can find there is only one running to the fpr and one running to the charcoal canister
Razi
Car: Moo
Maybe that's why you have a whack idle?You require some vacuum lines to be hooked up in order for a smooth idle.
hellzknight
that's not true, as long and there is no air in my vacuum lines there shouldn't be a problem.
Does anyone know how i can test the air regulator valve to see if its operating correctly?
mmaxeyjr
Car: 1995 s14
check your timing.
hellzknight
Timing is correct, i checked when i replaced the distributor
hellzknight
anyone?
hellzknight
anyone have any ideas?
mmaxeyjr
Car: 1995 s14
so i guess your MAF was dirty? you cleaned it and it fixed it right up??
hellzknight
i replaced it cause it had been hit with carb cleaner
mmaxeyjr
Car: 1995 s14
yeah i think my problem is more work than that
i believe that the timing w/ the oil pump is off which is causing the timing with distributor to be off also.
and i think i have a leaky fuel injector so i need to replace o-rings...
i wish i knew how to do this on my own.. i want my car fixed!!
spindrift187
why did you remove all that and leave the charcoal canister of all things?
Do you have a pic of your intake mani?
